WeMo smart plugs for lighting control
Discussion in 'Ask the Landscape Lighting Experts' started by Shaefer, Sep 19, 2017.
  1. Shaefer
    Shaefer New Member
    In place of the typical timer, is it possible to use a WeMo smart plug as the controller inside the transformer? From the Belkin site:
    GENERAL SPECIFICATIONS
    • Electrical Ration: 120V~/15A/60Hz/1800W
    From the Volt site on their Intermatic Astronomical timer:
    • 15 Amps, 1800 Watts Inductive
    • 500 Watts Tungsten
    • 125 Volts AC, 60 Hz
    Is this telling me that their basically the same as far as handling electrical loads? Thank you.
  2. MarcoP
    MarcoP New Member
    Following.. would like to know this too. We need smart timers/plugs. We should be able to control our lights with an app on our phone, just like everything else. Irrigation has that feature already.
  3. Sparrott4
    Sparrott4 Guest
    The specs look the same, but I don't know if it will fit or work inside a transformer installed outdoors.
  4. Dan
    Dan New Member
  5. MarcoP
    MarcoP New Member
    Anyone else have trouble losing signal from the WeMo once the transformer box is closed?
