Voltage drop
Discussion in 'Ask the Landscape Lighting Experts' started by Bruce Bruce Bogman, Jul 1, 2024.
  1. Bruce Bruce Bogman
    Bruce Bruce Bogman New Member
    Hello, I have a run that’s about 340 feet and it will be about 60 W total on 12-2 wire . i’m going to run it on a 15 V feed from the transformer. Is it OK to do? I know I will have a voltage loss but well, it still be within spec so the LEDs are not dim
  2. Robert Mason
    Robert Mason Veteran Member
    Bruce, the formula for calculating voltage drop is on page 9 of the installation manual for the 600W multi-tap transformer. 340 feet of 12/2 wire will produce a 5.4V loss and will probably not work for your application. The lights will likely dim or flicker, if they work at all. 10/2, or even better, 8/2 wire, would be needed to keep the voltage at the last bulb above 10 volts. Bob
