transformer to hubs
Discussion in 'Ask the Landscape Lighting Experts' started by mike 64, Apr 23, 2020.
  1. mike 64
    mike 64 New Member
    Can i run 3 hubs on a 100 watt slimline. 3 to 4 fixtures per hub
    Evan will correct me if I'm wrong but as long as you are 80 watts or under, you should be fine. If you've got longish runs that require heavier gauge cable, it's a good idea to give yourself a little bit more breathing room.
    In addition to keeping it under the 80% recommended usage (80W in this case) as Meso said, we typically advise against linking hubs/hub-to-hub connections as they can lead to voltage loss.
