Question re: Can I add an external Light Sensor on Costco 150w transformer
Discussion in 'Ask the Landscape Lighting Experts' started by Monty414, Jun 16, 2023.
  1. Monty414
    Monty414 New Member
    We just started installing a costco 3 path, 6 light set. Really happy with the quality, but have a question re: transformer installation: For logistical reasons, I have to install the transformer inside the garage. No window inside the garage for the sensor to pick up outside light. When i tested the system it works great, but I see that there is no time of day timer--timer seems to be based on the light sensor. (Makes perfect sense for an outside installation). Is there a way to add an exterior light sensor or program this for time of day or am I stuck. Appreciate any advice.
  2. Robert Mason
    Robert Mason Active Member
    Monty: You should give customer service a call to confirm it, but the Volt Mechanical Timer for Slimline Transformers should directly substitute for the supplied timer in the Costco kit. It will work without a photo sensor, but you would need to adjust the on-off times depending on the seasons.
    An alternative, which I use, is to leave the timer off and plug the transformer into a smart plug controlled with a smartphone app. The one I uses automatically adjusts the on-off cycle based on sunset-sunrise times for my area code.
    Enjoy your lighting package. You won't be disappointed. Bob
  3. Robert Mason
    I forgot, the Ring app stuff that Volt now sells would also be an option. Bob
  4. Monty414
    Monty414 New Member
    I called volt customer service today. They have pretty awesome support--got my answer write away. Simple order of a mechanical timer part that swaps out. Super helpful customer service at Volt!
