Photocell Adjustment for VOLT Slimline 100W LED Transformer
Discussion in 'Ask the Landscape Lighting Experts' started by chrisv, Jun 21, 2020.
  1. chrisv
    chrisv New Member
    is there any way to adjust the photocell sensitivity? I mounted mine in the garage and it doesn't recognize it's daytime during overcast or cloudy days
    Someone will correct me if I’m wrong but I don’t believe that’s possible. I think you’ll need to mount the transformer closer to a window or use a photocell extension cable.
  3. sagosto
    sagosto Active Member
    Why bother? Spend $8 for a smart plug and adjust it via app.
    When desiring dusk/dawn capabilities from a transformer mounted inside of a garage, we typically recommend considering a low-voltage photocell extension cord like mesodude mentioned.
    The light-sensing diode will get the most accurate readings being outdoors in mostly direct sunlight.
