Partially bury volt path light stem?
Discussion in 'Ask the Landscape Lighting Experts' started by Pete A Bryant, Feb 18, 2019.
  1. Pete A Bryant
    Pete A Bryant New Member
    The 12 inch path lighters are a bit taller than I would like. Will it void the Volt warranty if I partially bury them 3-4 inches?
    Hey Pete,
    Burying a path light stem in this manner will not void the warranty. While it will not cause any physical damage or harm the functionality of the light, you will more than likely notice a difference in color. The portion of the fixture that remains above ground will continue to patina and react to the surrounding elements whereas the unexposed portion will more than likely patina at a different rate.
  3. Pete A Bryant
    Perfect. Thanks Evan.
