Looped system
Discussion in 'Ask the Landscape Lighting Experts' started by Eric1960, Oct 29, 2020.
  1. Eric1960
    Eric1960 New Member
    With my Home Depot system I put in 15 years ago, I did a looped system, off the transformer terminal, run to furthest point and then back to the terminal block (Maintaining polarity). As I am preparing for a new volt system does anyone install using this method?
    Hey Eric,
    With low-voltage AC, there is no polarity to account for. So, you would not need to loop your setup if using one of our systems.
  3. Eric1960
    Eric1960 New Member
    Thank you Evan, the reason I looped ( from the transformer back to the transformer) is because the voltage drop is equal regardless where on the line it is. The furthest fixture is equal to the closest fixture
