Lights turning on and off
Discussion in 'Ask the Landscape Lighting Experts' started by Eric Krech, Sep 6, 2019.
  1. Eric Krech
    Eric Krech New Member
    My pathway lights individually turn on and off every few minutes, however my spotlights stay on. The wiring seems good, are there thermal cutouts in the bulbs causing this. It is all run from the same transformer
  2. Mesodude
    Mesodude Member
    What wattage is your transformer? How much capacity are you using? LED or Halogen bulbs? Are the path lights on a separate run or the same run as the spotlights? Thanks.
    Are the path lights that you are having the issues with on the same run from the transformer or separate runs? Are they on a hub by chance?
