I have a flood light that has started to pulse like a strobe light (not a strobe bulb). All other lights on the same circuit are fine. Any ideas
More info would be helpful. I've never heard of that happening before. Are these VOLT products? How old are the bulbs and how are they wired? By "on the same circuit" do you mean the light is part of a chain or do you mean its lead wire is attached to the same wire taps as the other lights?
An LED light source flickering could be a loose wire connection, or there could be issues with the LED light source itself. Be sure to double check the wire connection at that specific fixture! If the connection is not the issue and the bulb/fixture is one of our VOLT products, please feel free to give our experts a call directly. We can help with additional troubleshooting and set up a replacement order if needed.
