I just purchased a Volt transformer box that suppliers 12VAC. I have existing landscape LED lights that used to work with 12VDC. What is the best way to convert my current light fixtures to work with the 12VAC transformer power supply? LED lamp/bulb replacement?
I assume what you mean is that the Volt LED lamps will work with AC or DC power? Or that I need to buy AC lamps from Volt to replace my DC lamps?
All VOLT LED lamps can only be used with AC power. If you have DC lamps, you'll need to contact the manufacturer to ask if they work with AC.
