Looking to add spot lights and pathway lighting....would appreciate suggestions and power transformer model suggestions
Pathway lighting is an issue with me. What are usually referred to as 'pathway' lights are area lights - think mushroom-shaped. So the light it puts out goes equally all around the fixture; great for an annuals bed, for instance, but half the light on the edge of a pathway is lost behind the fixture. A pathlight is either one that is angled up a bit from the vertical, VOLT'S Traditions Pathlight, for example, or one that has a swivel head. Then most of the light can be directed onto the path itself. I'm disappointed that VOLT no longer carries a fixture with a swivel head, but other manufacturers do. (Hint, hint, if the moderator is reading this.) Since G4, bi-pin bulbs are usually no more than 4w, I like to make the most of the lumens available.
