Help with choosing beam angles
Discussion in 'Ask the Landscape Lighting Experts' started by Martin A, May 24, 2024.
  1. Martin A
    Martin A New Member
    I need help in choosing the beam angles for the lighting on our house. On the two columns with the yellow arrows, would 3w 38 degree beams work or should it be 15 degrees? I was planning on 3w 38 degree beams on the red arrows on the house and 3w 60 degree beams under the three trees. All would be 2700k
    We are planning to do moonlighting in the live oak trees. Our lot is 60 foot wide and the front yard is 25 foot deep. I have been told to use anywhere from 2 to 4 lights in the trees. What would be the appropriate number and what color temperature and beam angle should I use? Thank you for any advice you could give.
