Floodlight on switch -- how to wire
Discussion in 'Ask the Landscape Lighting Experts' started by Bryan Sauer, Jan 28, 2018.
  1. Bryan Sauer
    Bryan Sauer New Member
    I am going to install low voltage lights for the front of the house and a low voltage flood over the driveway that has a basketball hoop. I was hoping to only turn on the flood light when I want it for basketball -- so was hoping to put it on a switch.
    Can I just use a simple toggle switch and install it on the transformer? Not sure how to wire it exactly -- was thinking I would just take the wire connected to the 12V/15V clamp of transformer and interrupt it at the switch but keep the COM wire intact. Would that work?
    Any other advice?
  2. Lumiscape
    Lumiscape New Member
    I have used a switch to on/off the lights over a grill. I just found a convenient location for the switch and installed a 'switch loop'. Cut one strand of the main wire to the light on the B'ball hoop, connect a 2-strand wire, one leg to each of the cut lines. Run that wire to the switch location, install the wire to each side of a simple single pole switch, put it in conduit if necessary and an outdoor switch box, and voila, here comes LeBron!
  3. georgetv
    georgetv New Member
    Checking in here to see what you guys did. I have one light I want to isolate. Can I just do a low voltage switch on that one line?
    For controlling a single 12V fixture, a 12V toggle switch/relay on the wire run would be the easiest, most convenient method likely.
    One thing to take note of is - if the relay/switch is not properly stopping the flow of electricity completely to where the LED bulb/board is still receiving low levels of residual voltage, it could cause damage/unpredictable results overtime. A voltmeter would be handy for double-checking the current.
