Dim spot lights
Discussion in 'Ask the Landscape Lighting Experts' started by Anthony Gonzalez, Nov 6, 2021.
  1. Anthony Gonzalez
    Anthony Gonzalez New Member
    Our lighting has been great for the last 2 years. I noticed a couple of days ago that 4 spots on separate lines are lit but very dim. Is this an indication of a short or the bulb? Other lights on the same string are operating normally. Any help is appreciated.
  2. Evan K
    With the system having been previously working as expected for 2 years, it is likely not related to a wire connection or voltage issue - but this is always potentially worth checking. If you have a voltmeter handy, I'd check the spots where the fixtures in question are located.
    If these are receiving the proper input voltage ranges recommended for the fixtures (usually about 12-15V), then it is likely related to the LEDs (integrated or bulb).
    If the 4 fixtures use bulbs, double check that the bulbs are still secured properly in the light housings (sometimes fixtures can get hit and unseat a bulb). The next thing to do would be to test a bulb from a working fixture to help verify if the issue is related to the bulb(s) in the 4 fixtures.
    If the bulbs are ultimately the reason the light outputs are dim, under the lifetime warranty for our LED bulbs we can get these replaced. Just give our expert team a call directly with your order # or account e-mail handy: (813) 978-3700
