Cold weather expansion joint caulk?
Discussion in 'Ask the Landscape Lighting Experts' started by Ranio, Jan 22, 2025.
  1. Ranio
    Ranio New Member
    Ran a wire in a concrete driveway expansion joint.. needing to fill in the joint however temps are below 32 at night and rarely climbing above freezing during the day. Just caulk in the spring or?
  2. Robert Mason
    Robert Mason Veteran Member
    Ranio: A couple of options. 1) Buy some backer rod from Lowes or Home Depot. It comes in various diameters. Buy a large enough size to form a tight fit when you press it down into the expansion joint. This will protect the lead wire for the time being. When it warms up above 50, clean out the dirt from the joint, leaving the rod in place, and top it off with some Sika self leveling sealant. Seal off the ends of the expansion joint with wood shims to keep the sealant from flowing out till it sets up. 2) A more expensive option, but one you can do right now, is to buy some Trim-A-Slab expansion joint filler, again from Home Depot or Lowes, and install it over the wire. It also comes in various sizes. The Trim-A-Slab website has printable templates for selecting the right width filler for your expansion joint gap. Seal the ends of the filler with Gorilla Glue to hold it in place. I've used both options over the years for my drive way and sidewalk wire runs. They work equally well. Have fun. Bob
  3. laliagmapab
    laliagmapab New Member
    The following forms have been updated as of Jan 22:
    F12 Application for Senior Membership
    F13 CAP Aerospace Education Membership Application
    F15 Application for Cadet Membership in Civil Air Patrol
    Update your records accordingly.
    How might the strategic use of landscape lighting deter crime or alter criminal behavior in a neighborhood? Are there any studies or anecdotal evidence from your own projects that highlight a correlation between lighting design and community safety? ( darknet drug market darknet market links dark market url ) what is mean? and for what i getting it every day in my PM?
