Bypass Timer and Photocell / VOLT® Clamp-Connect 300
Discussion in 'Ask the Landscape Lighting Experts' started by ROSinclair, Mar 27, 2023.
  1. ROSinclair
    ROSinclair New Member
    I need to test the system during the day. How do I temporarily bypass the timer and photocell to turn the system on to do maintenance?
    Hi, ROSinclair. I'm not sure I understand the issue you're having. With either the built in or optional combo timer and photocell, simply turning the dial to the off position should disable the module. Same for digital timer. Which timer do you have? As long as it's not built in, you can always simply unplug the timer and/or photocell. HTH
