Blinking lights at the end of run
Discussion in 'Ask the Landscape Lighting Experts' started by Kelvin, Jun 6, 2024.
  1. Kelvin
    Kelvin New Member
    Hi,
    I installed 9 Volt RGB G4 infiniti lights on a 200 foot run with a 300 Watt transformer. Several weeks later the last few lights on the run began to blink. I removed the last light in the run and the other lights stopped blinking. I assumed it was because of a voltage drop so I purchased a 600 watt Volt transformer and added the light back to the end of the run but this did not fix the problem. What am I missing here? What can I do to stop the lights from blinking?
  2. Administrator
    Administrator Administrator Staff Member
    Hi Kelvin,
    Based upon the info you've provided, it sounds like the wire run is overloaded. With (9) RGBW Infinitis at 12W a piece, you have approx. 108W on that run - we typically recommended no more than 80W, or 8-10 fixtures per wire run from a transformer; whichever threshold you hit first.
    Splitting up that wire run should solve the issue!
