Beginner Question
Discussion in 'Ask the Landscape Lighting Experts' started by Gaumless, Jun 17, 2024.
  1. Gaumless
    Gaumless New Member
    Get ready to dive into the deep end of the hottest, rawest action with our smorgasbord of free porn tubes. We're serving up all the steamy sex videos you could ever want, featuring the most famous faces in XXX. These pornstars know exactly how to work it, getting down and dirty in ways you've only fantasized about.
    https://sexyxxx.ooo/sites/pure-mature/
    https://sexxxx.love/videos/130737/rough-monster-cock-anal-sex-for-skinny-green-eyed-teen-18/
    Looking for something fresh to get your engine revving? Check out our daily updates that'll keep your hand busy and your nights far from boring.
    https://en.livesexhere.cc/raisavawn
    From rough rides to sweet seductions, our stars are here to please. Crank up the heat with bombshell blondes, fiery redheads, and exotic beauties who all share one thing: they're horny as hell and ready to go.
  2. Administrator
    Administrator Administrator Staff Member
    Hi there,
    Our utility patented pro junction hub certainly helps simplify installation - it allows for making quick & easy wire connections at a single point of your choice. It also makes for easy expansion or troubleshooting in the future if needed. We'd typically recommend using fixtures with 25ft lead wires when trying to use a hub - shorter lead wires can make using a hub counterproductive, depending on fixture placement.
    Regarding voltage and if you should increase, if 25ft is the maximum distance away from your transformer, the standard 12V tap would be ideal.
