Adding light to pool wall
Discussion in 'Ask the Landscape Lighting Experts' started by janis5151, Jul 13, 2020.
  1. janis5151
    janis5151 New Member
    So I need the best way to add light to the pool wall in these pictures. I have up lighting for plants, however, you will see what is missing at night!! I need it to be in the ground in front of the pool (where the rocks are) and shine across to it. Wall is about 15-20 ft across and the area the lights will be is about 20-25 ft away. Maybe a multi-mount with 2 lights or just one? What lights should I get to throw that far?
    Nice pool!
    For low-voltage landscape lighting, it would likely be best to illuminate the wall from either the sides where the potted plants are at, or downlight from the top of the wall. A combination of the two could look great as well.
    Low-voltage lighting is typically not rated for swimming or immersion so, if you desired illumination from below I'd recommend looking into traditional 120V pool lights.
  3. janis5151
    Can you make suggestions on what lights to use from both areas?
    Sure thing.
    A compact MR11 or MR8 spotlight could provide beautiful illumination from either side within the pots while remaining mostly hidden to conceal the light source - a popular MR11 fixture is the All-Star™ Mini Spotlight , and the Spark Spotlight for an MR8 fixture. The MR8 option would be a much more subtle output.
    Difficult to tell from the photo but, if there is potentially a lip at the top, you could consider mounting a compact LED Puck Light for subtle downlighting on the middle portion. But, this might be a little labor-intensive and truthfully the (2) spotlights on either side will likely provide plenty of balanced, subtle illumination for the entire wall.
