Can I wire 2 lights to one hub connection? I need one more connection and I have used all 8 connections already. Thanks.
I don’t know but given that the product description states that the hub accepts “up to” seven fixtures, I suspect not. I know it’s acceptable to use multiple wires per transformer tap but it may not be similarly acceptable to share ports on hubs. Since we wouldn’t want to do anything that could void your warranty, it’s probably best to consult customer service.
LED is quite flexible - you could technically do this and still likely receive full illumination from both of the fixtures in that single spot. A voltmeter would help verify. But, if the HUB were to experience any damage or fail as a result of more fixtures than recommended or too large of amperage, this would void the warranty - just a heads up.
