Need suggestions for new landscape lighting placement!
Discussion in 'Ask the Landscape Lighting Experts' started by kitty, Sep 12, 2025.
  1. kitty
    kitty New Member
    Interested in Pathway lights and using uplighting/spots on House. Looking for a “soft” illumination, not overall bright. Trying to understand proper beam usage as well as lumens to keep light softer and also eliminate glare from doorway and windows.
    There is a small beech tree on the left side front corner of landscaping that is a bit hard to see in these photos. Two large Holly trees are a focal point and want to eventually upright these. The front beds by walkway are planted with mini hydrangeas which will fill most of the space. Would like to light column that might go all the way up to roof line or above. Thanks in advance for your thoughts and recommendations.
    Hi, kitty. I’ve diagrammed one of your photos to demonstrate one possible approach to lighting your home. This is a very accessible plan that highlights the more remarkable architectural features including the brickwork at corners, your columns and the lighter colored areas (gable and dormers). I originally meant to indicate a light for the wall section below and to the right of the first level dormer closer to the main part of your house. But if you’re erring on the conservative side (as it seems you’re indicating), I don’t think you’ll lose anything by omitting a light there. In fact, if you wanted to, it’d be fairly easy to really trick out your house by light that area, the area between the two windows on that smaller section of your house, your flag, and the area between the pairs of windows on the main part of your house. But my mindset is that sometimes more is less and I’ve always liked the idea of leaving certain areas of a house and landscape unlit. That way, the viewer is invited to sort of fill in the blanks, so to speak. If you stick with fairly narrow beam spreads (+/- 15° to 20°) for all areas accept for the gable (a 60° should be ideal there, imo) and keep your lumens no higher than 3W, I think you’ll end up with a coherent, and compelling plan that doesn’t overpower the facade of your house. I actually think 2W spotlights in all of those locations would be ideal. Unfortunately, VOLT doesn’t make configuring narrow beam spotlights in the 2W range as straightforward as it could be, imho. The spotlight I recommend most often is the regular sized version of the Top Dog. IMO, this is the most versatile and configurable of all of the spotlight models VOLT sells. In order to avoid your windows and avoid introducing more light than you want to your property overall, I think you may want to go with adjustable beam spread lamps for your Top Dog fixtures and you also might need to use frosted lenses and/or hex louvre filters to tweak your light output and your beam spreads.
    The blue circles indicate possible locations where you might place path lights. Unfortunately, from your photos, I don’t have a clear sense of how long or wide your walkway is. The specific path lights fixtures you choose will depend on whether you want your walkway fully illuminated or you want to illuminate it with distinct pools of light with some space in between. So, for example, if the main length of your walkway leading from the house is 20 ft, you could choose to use just a couple of path lights with very wide beam spreads (like the Max spread pathlight) or you could use more fixtures with smaller beam spreads to light your path in a slightly different way. It sounds like you have a few different trees and shrubs in mind to light. My advice to you is to choose wattages in the 1.5W to 2W range and try to vary your lighting techniques to add interest to your plan. For example, you could leave that conifer there in the front unlit (so that it’s silhouetted by the illuminated wall section behind it, you could front light it with a single spotlight or floodlight or you could flank it with two spotlights (for a more three dimensional effect). Whichever trees and shrubs you choose to highlight, try to use different techniques throughout (rather than simply uplighting everything), to give your plan complexity. Btw, I really like the different layers and rows of shrubbery in your front yard and I encourage you to highlight the different areas (and you can do this as subtly as you want) that display this structure at night. HTH to get you started.
  3. kitty
    kitty New Member
    image0.jpeg image3.jpeg image2.jpeg image1.jpeg Here are more pictures for depth. I appreciate your ideas and like your thoughts. I definitely want to light the columns and hope the beams might reach up to the lighter section over the door. I am not sure I want to put lights on the second story right now. Is the a beam/watts that will reach that high? They could be placed farther out toward the boxwoods, but again I am trying to manage glare also. If you have additional thoughts once you see these photos, please send. Tree on right side of house has shed great amounts of leaves, but both are large Holly Trees. Depth of the overall Brick pad from front door is just under 6’ and the total depth to the front of the boxwood hedge is just over 21’. Hope that gives you a better idea of the over all size! Thanks again
    Glad to help and thanks for taking time to post more photos. I think a single ground mounted fixture (as opposed to mounting fixtures above your columns) should work. I initially had concerns about a large shadow possibly being produced due to the lip/ledge between your columns and the section above that. Judging from your additional photos, it’s not a very deep ledge and so I think if you bring your spotlights away from the foundation far enough, you should be good. 2W spotlights on the facade of our house are able to reach the 18’ 20’ feet distance from ground level. But before you commit to a certain brightness level, it might be a good idea to experiment with a 2W lamp to confirm it will suit your needs. If not, a 3W should definitely do the job. As I mentioned before, among the ways to address glare or concerns about over lighting, are frosted lenses and honeycomb filters. Btw, the color changing bulbs and fixtures are dimmable. Experimenting with one of these is another way you can zero in on the lamp brightness that will work best for you.
  5. kitty
    kitty New Member
    Thank you very much for your input and help!
    You’re welcome. I totally empathize with you wanting to introduce lighting to your home and landscape without overdoing it. One thing to keep in mind is that when you light trees, shrubs, plants and objects that are fairly low to the ground, there’s really no need (IMHO) to use 3W, 5W and higher lamps in your fixtures. IOW, if it’s in your budget, don’t be afraid to experiment with some of the smaller fixtures with lower lumens lamps. A little light really does go a long way. Finally, the colors on your house are quite warm. Before you commit to a color temperature for the entire facade, I recommend you try out (not unlike you would a paint color) the warm white 2700K vs the slightly cooler 3000K on a wall or two to see which one you like better. In my experience, 2700K can make certain warmer color schemes look gloomy. The opposite is also true. A 3000K lamp can make a house that’s grey, a cooler shade of blue or bright white look chilly or sterile. The most cost effective way to experiment is to get one of each color temperature or try one of the color changing bulbs (which will allow you to select from among multiple warm and cool color temperatures). I encourage you to show off your WIP or your final plan.
