My Landscape lights stopped working
Discussion in 'Ask the Landscape Lighting Experts' started by John Knight, Aug 30, 2025 at 11:38 AM.
  1. John Knight
    John Knight New Member
    I have a 150amp box, that feeds a line out to a HUB . I checked the power line into HUB and it has power going in but none of the lights are working (so I guess no power coming out. How do I troubleshoot and what could be the cause? what do I need to look for? I put everything in about 3yrs ago
    Some possibilities:
    A.) Faulty terminal connections at 1 (transformer) or 3 (hub) or faulty connection at 5 (splice point).
    B.) Wire severed at 2 (main wire to hub) or 4 (lead wire between hub and fixture)
  3. John Knight
    Thank you for the Trouble shoot map.
    A. Did not check faulty terminal Connection since I Took that Main wire (2) out of hub and it had power.
    (but if there is a faulty wire / connection with 4 would that make all the lights not work? because none of them are working)
    B. My second move was to move 2 to a different location in the hub 3
    It wasn’t clear to me how your lights are wired. If the light at 5 is the first link in a chain of lights extending from the hub and it’s the only run in your system, then that might explain why all of the lights aren’t working. If you have multiple light runs connect to the hub and those are out too, then something else is going on.
    It would be helpful if you could describe your lighting set up in more detail. How many lights are we talking, for instance? Did something remarkable happen recently that could explain why the bulbs would go out? Are these VOLT products? Have you confirmed that the bulbs in all the fixtures are still good? Just trying to make educated guesses.
  6. John Knight
    I have each light running back to the Hub (3) ..
