Transformer LED Indicators - Older Costco Model
Discussion in 'Ask the Landscape Lighting Experts' started by dmcknight123, May 20, 2025.
  1. dmcknight123
    dmcknight123 New Member
    I have an older Volt kit purchased through Costco with a 150 watt (I think...maybe 100) black plastic-cased transformer. It's worked well for several years. A couple weeks ago we had a nursery come out and revamp some landscape and they inadvertently buried it. Maybe it had already fallen over, I don't know. Anyway...a couple good watering sessions later and our landscape lights quit working.
    I don't find anywhere on the Volt site where I can view discontinued products and the Costco order is so old it doesn't come up in my Orders so I'm unable to provide a model number (at least until tomorrow when it's light and the weather is better). But here's what it's doing - the green LED burns constantly so I know it's getting power. There is one other button that when pushed cycles between 2 hr, 4 hr, etc and I believe just a constant ON which is what I want. But that LED is red. Is that normal? Is there a fuse somewhere to look for?
    Thanks in advance for any info!
    Just guessing here but I suspect you have the transformer from Costco shown here. If so, the red light is apparently normal. In some transformers, a red light usually indicates a short circuit or some other type of fault. Being virtually submerged may have damaged it but I think your best bet it to contact VOLT customer service and ask them for troubleshooting instructions. There may be a way to power cycle it, to reset it. I’m not aware of any user serviceable parts (like a fuse) but if I were you, I would unplug it immediately and allow it to dry out completely before attempting to use it again. HTH
  3. dmcknight123
    Yes, that's it exactly. Contacting them was my next step. Thanks!
