Red Black White Jumper
Discussion in 'Ask the Landscape Lighting Experts' started by datcope, Nov 2, 2018.
  1. datcope
    datcope New Member
    What do I with the (2) Black Red White jumpers that were included with the 300 watt transformer?
  2. datcope
    datcope New Member
    Hello datcope,
    This jumper cable is included complimentary with our transformers in the event that a photocell or extension cable which does correspond with the photocell plug in the transformer is used (i.e. male plug to male plug, or prong-to-prong).
    The part is not always required for operation but, it is certainly handy to keep around for possible future purposes!
  4. datcope
    datcope New Member
    Evan,
    That is one more reason I am excited that I found you guys! Thanks for the answer to my question.
  5. Community Admin
    Thank you for the kind words!
    Glad to be of service!
  6. DaveRodda
    DaveRodda New Member
    Without actually seeing a diagram of that unit, I would suggest that the secondary is the two red wires. You would see about 15 volts ( open circuit). That is about normal to give you 12 volts under load. The white wire is the center tap, hence 1/2 the voltage from each red to the white.
    percentage calculator
