Flickering light
Discussion in 'Ask the Landscape Lighting Experts' started by Howard Bozenhard, Jul 10, 2022.
  1. Howard Bozenhard
    Howard Bozenhard New Member
    I have several volt hard scape lights. One is dim and flickering. Replacing the bulb does not help.
    Is it possible to replace the socket? The fixture is set under a stone cap and can’t be replaced.
    Hey Howard,
    If you've swapped a known working bulb into the fixture in question and it still is not operating as expected, under our lifetime warranty, we will send you a shipping label to get the unit back in house for inspection where we can either repair or replace the fixture.
    If at your earliest convenience you could reach out to our lighting experts, we can work to get you quickly taken care of! (813) 978-3700
  3. Howard Bozenhard
    Thank you, yes, I replaced the bulb with a known good one and the symptom is the same. The fixture is installed under a stone cap and there is no way to remove it.
    I was hopeful that I could try to replace the socket?
