Extensions with solar lights?
Discussion in 'Ask the Landscape Lighting Experts' started by Tony P, Feb 19, 2022.
  1. Tony P
    Tony P New Member
    Can Volt extension risers (VAC-RS2-BBZ)
    be used with the Volt solar lights (BDL-VSPL-1045-BBZ)?
  2. Robert Mason
    Tony, it appears to me that the 12 inch riser that comes with the lamp is the same as the individual 12 inch riser that is available separately, so, yes, you can extend the light to whatever height you desire with additional riser length. Bob
    Hey Tony,
    Bob is correct - the bundle itself does include the normal 12" solid brass riser as a necessary component with the solar light housing.
    You could add another riser to this assembly, but the design is more so tested & optimized for use with the 12" riser. Given that this solar path light is designed for subtle output (~200 lumens), adding additional height could slightly diminish the amount/strength of illumination you receive on the ground below. Doable, but not exactly recommended.
    Robert Mason likes this.
  4. Robert Mason
    Good point about the light output. Bob
