How would you light up this cabana?
Discussion in 'Ask the Landscape Lighting Experts' started by DIY - Jersey Shore, Aug 12, 2021.
  1. DIY - Jersey Shore
    DIY - Jersey Shore New Member
    Hey there,
    We can definitely help with general recommendations for placement and fixture type.
    Are you looking to illuminate the home and the garden area?
  3. DIY - Jersey Shore
    Just to illuminate the cabana. I put up a 38 degree 5 watt light at each corner, but it is too dark in middle. Not sure if I should try to a put a light between each window.
    The window placement definitely makes trying to keep the light symmetrically balanced a bit tricky.
    Using the same up lighting approach, IMO I'd likely say your best bet would be to consider a single spotlight between the (2) middle windows with the narrowest beam spread possible for the fixture you chose.
  5. Alan B Founder VOLT®
    Alan B Founder VOLT® New Member
    i would go with a lower lumen output lamp like a 3watt. Its a short building and you want subtle light. Either two at each eand like you said or 5 (2 at the ends and 3 between the windows) but use low wattage.
