Direct Bury Cable
Discussion in 'Ask the Landscape Lighting Experts' started by Jim Rossi, May 13, 2020.
  1. Jim Rossi
    Jim Rossi New Member
    Can the Direct Bury cable be exposed to the sun ? I have to run a length of cable from the back of the house to the front and the most direct route is a crossed the garage door header. Can the cable be exposed to the sun/weather or is it best to run it through a conduit ?
    Should be UV resistant and it should indicate that on packaging. I think ideally it should be buried but protecting sections that will routinely be exposed to sunlight seems like a good idea. I've buried only the cable that's vulnerable to foot traffic or lawn maintenance. Where that's not an issue I've hidden it beneath shrubs and mulch
