Installing 10 All Star Brass Tommy Lights and 10 Volt Deck Lights , running off a 600 watt 12v/ 15v multi trip low voltage transformer. Run is aprox. 175 feet, I want to use Pro hubs to connect my different areas. Can I connect one hub to another or do I have to start each hub from my transformer?
Hello Billy, Generally, we advise against using hubs in this manner as it can lead to oversized runs which may experience voltage loss and cause unpredictable results within your system. It is certainly possible to use multiple hubs in a project on a single transformer, just be sure to power each individually from the main supply of power!
