Low Voltage Lights/Remote Control - Setting Up Zones
Discussion in 'Ask the Landscape Lighting Experts' started by Minitwo4, May 15, 2025.
  1. Minitwo4
    Minitwo4 New Member
    We have 5 x Volt RGBCW flood lights wired into a Volt 600w multi tap low voltage transformer.
    I attempted to pair the remote control (VAC–REMOTE -RF3) with two zones. One zone of four lights facing the house and the other light in a zone of its own shining on the flagpole. Having turned the transformer on, the lights were flashing indicating pairing mode. I pressed button one - but this has now put all the lights under one zone.
    The manual gives instructions on un-pairing a zone, but can someone please explain to me how I can separate the lights into two zones while the lights are in pairing mode
    Thank you for any help!
    I don't have these products yet but the way I interpret the instructions, only the unpaired light(s) you want to assign to each specific zone should be powered on as you create that zone. IOW, pair the four lights and then assign them to a zone. Then, insert the bulb(s) for the next zone you want to create, pair them and assign them to a zone, and so on. You may also want to check out the video tutorial (linked below), if you haven't already. If all else fails, try contacting VOLT customer service and ask someone to describe the process for you more clearly. HTH
    https://www.voltlighting.com/learn/how-to-set-up-volt-color-changing-led-landscape-lighting-bulbs
  3. Minitwo4
    Minitwo4 New Member
    Thank you. Will check into this
    Update: I spoke with customer service this afternoon and was told that the way I explained it was in fact the proper procedure. You want to connect your fixtures (or insert your bulbs) then pair and assign a zone to that group of fixtures or bulbs. Then connect the next group of fixtures or insert the bulbs into your next group and then pair and assign a zone to them and so on. I also learned that when you have a fixture with two bulbs (like the up/down lights or dual head path lights) and you want to assign each bulb to different zones, you follow the same principle. Insert the first bulb into the fixture, pair it, and then assign it to a zone. Then insert the second bulb, pair it and assign it to a zone. HTH
